04 FXT Partout Leftovers - lots of Impreza crossover parts
Car Info: Reason
Hi All -
-OEM 04 FXT head unit w/subwoofer + both subwoofer plugs so you could build your own harness. It just takes 2 wires, but I didn't want to fish the whole thing out front to back. $100 for both.
-Stock OEM IC FXT splitter + stock JBP scoop. Fits 02-03 WRX and 04-08 FXT. $50 for both.
-04 STi rear struts. Slight clunk in the right strut, so should need a rebuild, which is a very easy DIY process. Don't have the fronts. Fits 02-07 WRX. $100 OBO for both.
-04 FXT steering wheel. Needs the cruise control plug replaced, as I removed it for an 06 STi wheel swap. Everything else is intact and in great shape with very little visible wear. $100
-Rear wiper arm and motor. Fine shape. $50
-Fancy Bosch front wiper blades. Almost brand new. $20
-All 4 seatbelts. Includes all winders, harness pigtails, mounting brackets, and hardware. These are in excellent condition, and super expensive from the dealer. $150 OBO
-Stock OEM turboback exhaust + OEM exhaust manifold. Very good, used condition. $OFFER$
-Stock OEM intake manifold. Same as 04-05 STi, just not red. Fits all DBW 2.5L Imprezas and Foresters up to 08. $100
-Stock OEM rear brake calipers. Include pads, mounts, and brake lines. Fits 93-07 Impreza. Same as 02-05 WRX. $50
-Stock OEM STi fender braces. Excellent, used condition. $20
-Stock OEM STi 20mm rear sway bar. Very good, used condition. $30
-Armrest extension. Very good, used condition. Fits 05-07 Impreza. $40
-Cobb non-adjustable, heavy-duty rear sway bar mounts. Fits 02-07 Impreza + 04-08 Forester. Excellent, used condition. $60
-Whiteline spherical bearing adjustable endlinks. Very good, used condition - can be deployed front or rear, and are very useful for corner balancing. Fits lots of other stuff. $50
-Stainless Invidia catless up-pipe. Has EGT bung that keeps sensor out of exhaust stream to avoid CEL. Fits 02-07 turbo Impreza, 04-08 FXT, and some Legacy models. Very good, used condition. $80
-Heated mirrors with dash switch. Very good, used condition. $125
-04-05 FXT foglight bulbs. Brand new - still in dealership packaging. May fit other years/platforms. Do your research. $25
Best way to get ahold of me is via email:
waltness [at] gmail (dot) com
Thanks!
Edit: pictures!!
Thanks!
Edit: pictures!!
fr0st_wrx
01-12-2016 01:14 PM
