6 speed sti vs 5 speed sti transmissions...
Old 09-21-2008 | 07:02 PM
mtcs's Avatar
Car Info: 2000 Subaru impreza RSTI
I’m still undecided about what to do about my tranny situation over the winter....
As of now I still have my stock 2.5rs 5 speed tranny in the car....beating the crap out of it and it is still going....13.07 @ 107
Really only has to last until the end of October then it is garaged for the winter. So, doesn’t matter what happens to the tranny.
Anyways....plan on putting something a little stronger in subaru over the winter...
Decided against PPG or RA gears due to the weakness that I have to use my rs tranny case. The case is weak as hell and torsion will bust my new gears. So I am deciding to do one of two things:
1. 6 speed sti conversion swap
or
2. older style sti 5 speed tranny...(4.44 gears)
Looking to make this into a drag vehicle so it must be able to handle power well. I have an incredibly fast Evo that I need to put the smack down on!
Thinking to myself...the 6 speed would be able to hold a ton of power, but the gearing is not right for the drag strip. On the other hand, the older style sti 5 speed trannys that are 4.44 geared must hold a lot of power since they were made originally for the sti in Japan....
Is there any truth to my thoughts? Could I use a 5 speed sti tranny and romp on it with my winter goal of 450-550whp?
Thanks,
Ben
Old 09-21-2008 | 07:45 PM
Dnayukns's Avatar
Car Info: 07 Wrx
Sounds fair enough, On the other hand, the older style sti 5 speed trannys that are 4.44 geared must hold a lot of power since they were made originally for the sti in Japan..... Id figure that would be fine, but then again those jdm sti's arent holding 450-550whp. Might just go with the 6speed to be safe.
Old 09-21-2008 | 07:51 PM
03_Impreza_Al's Avatar
Find a 03-05 WRX 5 spd that has been borked and get PPGs installed.
Old 09-25-2008 | 09:00 PM
WRX409's Avatar
Car Info: 04 WRX
^ This would be my recommendation also.
Welcome to i-Club!
deeferg
11-18-2008 08:34 AM
gruppe-s
Engine and Drivetrain
07-21-2006 01:32 PM
gruppe-s
11-18-2005 06:50 PM
gruppe-s
Vendor Group Buys/Specials
17
04-29-2005 04:42 PM
gruppe-s
09-19-2003 08:22 AM
Quick Reply: 6 speed sti vs 5 speed sti transmissions...
