TurboXS UTEC Subaru STI/FXT 2004+ Map/Lag Switch - $999 (cupertino)
Brand New in the box
Functions:
Plug-&-Play
No cutting, splicing or additional sensors required
20 minute, do-it-yourself installation
End-user programmable via PC,PDA with HyperTerminal, and our Game Boy and Smart Cable (coming soon)
Fine tune the maps for your exact setup
Pre-programmed base maps get you started quickly and safely
Base maps for our Staged upgrade packages
Five (5) maps plus “stock mode” selectable with a flick of the switch
Create custom maps for street gas, race gas, nitrous, or whatever
No need to lug around a laptop just to switch between your program
Optional remote swtich
Fuel, ignition timing, and boost are programmable in 250rpm increments up to 9000rpm over 10 load sites
Complete ignition timing control
Fuel control
Controlled via MAF sensor signal offset
Tune stock and larger than stock injector
Load reference
MAP (manifold pressure)
Closed loop boost control programmable via Throttle Position and RPM
Knock control
Automatically retards timing when the knock is detected safeguarding against engine damage
Adjustable knock threshold, timing correction, and duration
On board data logging
Built in programmable solenoid controller
Control Nitrous, Water Injection, Intercooler Sprayer etc.
Drag racing launch control (secondary rev limit used during launch)
Bonus:
The UTEC Map switch plugs into your UTEC for easy switching of maps. The UTEC has capability of holding 5 different maps and this switch allows you to easily change maps on the fly without having to have your computer connected. A must for UTEC.
Pictures avaliable upon request...
Functions:
Plug-&-Play
Fuel control
Load reference
Knock control
Bonus:
mmboost
10-14-2007 04:57 PM
IMPREZIN
08-11-2006 10:58 AM
imleepy
08-08-2006 10:56 AM
