wrx engine and tranny swap into legacy
has anyone every seen or heard about a wrx engine and tranny swap into a legacy. if so could u plz pass along all the information. im lookin in to doin on my 98 legacy.
Car Info: BH Legacy, white/black
It's basically the same process as doing one into a GC Impreza. I've done those. One thing you should decide before starting is if you want to try and use a WRX ECU to run your car or use a standalone system to run the engine and keep the stock ECU to run all the rest of the stuff in your car.
Also think of what your ultimate goal is as far as power and driveability.
Basically you will need the engine, tranny and rear diff, ECU and wiring harness, subframe and front sway bar. With the engine you also need headers, uppipe and downpipe (unless you plan on going aftermarket). You will also need a catback system. If you plan on doing performance beyond just the swap, better to do it now. The one I did we also did an PDE up-pipe and down-pipe, DP-back exhast, oil pressure guage and boost guage.
There are a few bits and pieces needed but I will have to check the spec sheet to remember....or maybe someone else can fill in the blancks.
thx man i greatly apreacte it. i was think that u would upgrade the comp to the wrx ecu. the one thing that i need to know is that it will all fit and that they use the same engine mounts
Same engine mounts for sure. As for the ECU, it works but that is the big pain in the ***. Wiring is a beehatch, especially for the first time.
There is an article in Sport Compact Car in the last couple of months on the swap into an older Impreza. I agree the wiring did sound like a pile of work.
DC
DC
Some guys in Toronto did it a while ago. Lets see if I can dig up the thread...
https://www.i-club.com/forums/showth...light=wrx+swap
Also, dig around a lot on nabisco and here. If you are going to actually do this, i would highly suggest also calling I-speed or another speed shop like that that does swaps fairly reguarly as it is not as easy as it sounds. The mounting of the engine and tranny is easy, but the tough part comes in the wiring which takes even a vetran mechanic 35+ hours to work though.
Mister 2
05-11-2006 07:21 AM
annointed
Subaru OEM Parts For Sale
07-21-2005 02:32 PM
92talonawd
06-06-2005 12:20 PM
Soobie22
12-11-2004 07:43 AM
