Legacy water pump replacement.
Hello to all.
I have just become the owner of a '96 Subaru legacy.
I picked it up three hours from home and drove it for an hour before the water pump locked up intermittently and I lost all the coolant out the front of the motor
by the crank pulley. I parked it and had to go back to get it with a car hualer.
The car was parked for about six months before I got it, which probably explains the water pump failure.
Although I am an experianced mechanic myself (27 yrs)
and work on some of the IHBA dragboats you see on Speedvision,
I am totally perplexed as to why I cannot find the water pump on this car.
It seems to be behind the cover around the crankshaft pulley.
This is the first horizontally opposed engine I have seen since the Volkswagon.
Can anyone post a drawing to clarify things for me?
Thanks,
Tim
Thanks,
Tim
It is behing the timing belt covers. It is alot of work but you get to know your engine real well. I attached a pic here to help you.. I have a 98 LGT and it should not be too different. Hope these help.
JMeltzer4
11-19-2012 04:15 PM
