coolant temp sensor location
i have a 95 legacy w/ the 2.2 and i can't find the ect sensors location. does anyone have a tutorial or how-to somewhere?
thanks
thanks
Admin v2.0
Car Info: 02 Black Legacy GT
The stock coolant sensor?
If yes, then it is located in the upper water pipe. The aluminum pipe bolted to the top of the block. It has a triangular 3-wire plug.
Hope this helps,
- Alex
Hope this helps,
- Alex
thanks for the reply. i went to the subaru dealership and picked up a coolant temp sensor. it has a brown rectangular plug. the part number is 22630AA041. is this the right part to replace if i'm getting the CEL for code 115?
thanks
thanks
A '95 would have a 2-prong plug. I did get a P0115 code and replacing the sensor solved the problem.
WindCloud
08-05-2004 01:08 AM
ralliecrazy
15
12-28-2003 10:12 AM
Impreza_WRX_STi
12-01-2003 11:34 AM
Impreza_WRX_STi
10-06-2003 08:52 PM
Impreza_WRX_STi
10-06-2003 07:30 PM
