Need help selecting a battery.
Car Info: Blaze yellow WRX 2002
I have a 2002 WRX and I have had some electrical issues but that is not what I want to talk about. I want to get a new battery for my car that is a little stronger. I want somehting that is radio/amp friendly but also somethign that is goign to do well for cold starts.
What are some good batteries that I can purchase that are easy slip ins to the 2002 WRX that will give me more juice for what I need?
Optima 35R....If you don't want to talk about your electrical problems, why did you mention them? Did you fry something?
C'mon....give....wassup?
Ok what type of Optima? Which one is the one that will fit the best? I want to try and get something that will sip into the existing battery holder if possiable.
Well I hooked up those lights that you see on e-bay. They are black with dual small headlamps. Well when I hooked them up originally there was not enough juice to power the brights caause when I turned them on both lights just dimed. So I rewired for one bulb to be normal and the other to be my brights and just played with the directions of each.
Well soon I found out the hard way that they were drainig power on me. While at stop- say in traffic my volts will drop down below 13 and sometimes below 12V. I hit bad traffic one day and the car just stalled out cause the battery got too drained. I think between some interior lights, my amp for speakers and amp for sub and the lights it is draining too much juice. Maybe it is the alternator but normally it sits at 13V so I am nto sure. I should probably go back to the stock headlights.
Car Info: 2005 Aspen White Subaru STI
Like I said in your other post, Optima has a new yellow top for sport compacts that is half the weight and size of the regular battery. Great for stereo systems. I have seen them for sale through summit racing.
Why yellow top??? YOu guys are confusing me here. I thought red top was the one that fit and worked best? A red top 35 (reverse terminals if they have that or if that exists)
I can not find many places online that sell these batteries. At least not a 35R
Car Info: 03 MBP WRX 06 CGM FORESTER XT
The Redtop should be fine - it's a standard replacement battery (you can even get them at Costco now BTW !!!)
Yellow Top is meant for cars with lot's of accessories that need to be powered (even with the car not running) It can be power cycled without effecting the battery unlike standard batteries. Their literature states that vehicles like ambulances and fire trucks usually benefit with the yellow tops.
Either would prob. be an improvement over the stock battery
Originally posted by jasno999
I need something that is going to give me a good amount of cold cranking amps fpor cold starts.
YEs but red top verses yellow top.
I wanted something that I could just drop in and have it work but nobody seems to offer the reverse terminal type 35 red top battery. And I would have to do modifiations to make the regular 35 type work. The terminals are on the wrong sides
look into the optima RED top. it's a direct replacement for the stock impreza battery. with the yellow top, you might have to mod the battery tray or rods to get it to fit correctly. i went with the red top and it took 5 mintues to swap it out.
