HID hook up: Source parts for a 9007 plug?
I am trying t install my EDM STi Projectors with a Mr. Jung HID kit and Jim Hoyd Harness. I am attempting to modify the harness to accomodate the HID and have only one part left:
I need to find out where I can get the crimp on connector that attaches the wire into the 9007 female plug. The crimp on connector itself is a barbed male affair so that when you slide it into the (female) 9007 connector it sticks out to mate up with the male 9007 connector and won't get pushed back out. The spade itself, besides being barbed, is VERY narrow (maybe 2mm) and long.
Anyone know where these can be sourced? (See picture)
I would check out Radio Shack. They have plenty of connectors. What you find will probably be a bit wider than what you need. Just get a dremel tool or something similar and grind it down until it's narrow enough to fit. I wouldn't worry about the barb, the connector should fit tightly enough w/o it. Good luck to ya.
file_id
SoCal Classifieds
01-17-2006 11:34 PM
impreza188
11-16-2003 05:54 PM
