front badge & fog light removal-help
I drive an '02 WRX sedan. Here are hopefully a few easy questions for someone:
1. I have a new badge for the front grill, what's the easiest way to remove the old one?
2. I need to replace a fog light that's blown. The manual says to take out three screws and pull out the fixture. Looks like the screws aren't easy to get at. Help? Thanks.
emblem- use a heatgun/hairdryer to heat it up first. then take a
small - screw driver and pull it out. becareful not to dent the
trimming around the emblem.
fog-i think it was a 10mm nut. just get an extended socket
or a long + screw driver. very easy to do.
i dont know about the fog lights but for the badge take a small screwdriver with a blad thats not ver thick and put in the side and pry it off. I took a paper towel and put it over the blade of the screwdriver so it wouldn't scratch my grill. It comes of fairly easy. And when i repainted that badge and put it back on i used silicon instead of double backed tape, dont know which is better but i know silicone holds very good.
1FSTREX
06-26-2009 06:07 PM
sjice
02-28-2007 06:52 PM
DaFastOne
06-22-2005 06:51 PM
DaFastOne
06-16-2005 05:51 PM
