Wiper Blade Replacement - Aftermarket Blades
I just did is for my Tribeca but I'm guessing you can get the right blades for most any Scooby. This is if you just want to replace the rubber part in your OEM blades.
http://www.scoobymods.com/forums/showthread.php?t=8727
Hope that helps someone, the only thing you need to figure out is the width of the blade top to get the appropriate PN from Trico. The parts counter guy got me the right numbers right away.
