stripped oil pan bolt
Old 06-07-2010 | 09:11 PM
dscoobie's Avatar
Car Info: 2004 Subaru Impreza Wrx
Hey,
I was replacing my oil and tightened the bolt to the oil pan without a crush seal on it and now i have a tiny oil leak due to the stripped threads on the oil pan. I had replaced the bolt and put a new seal on it and still leaking. I wasn't sure if i should use a keensert or a heli-coil to fix the problem.
Old 06-07-2010 | 09:38 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
Replace the pan.
Old 06-26-2010 | 03:33 AM
JJ3810's Avatar
Car Info: 2010 WRX
You might try a (thicker) flat washer AND the crush washer and see how that works.
Old 06-29-2010 | 07:20 PM
getsum750's Avatar
Car Info: 04 Subaru WRX STI PSM
There is plug you buy that when you tighten it the threads expand in the hole and it will stop your leak I've used them before and alot cheaper than replacing the plan...Also Heli-coil works very well if you want new threads.. Or another ghetto fix would be to get a crush washer and put high temp silicone on the washer and tighten it all back up....Good Luck!!!
wrecker83
10-12-2008 01:05 PM
bringndefinitio
03-17-2006 04:53 PM
Dinko81
12-30-2003 05:52 PM
awd4ever
11-10-2003 02:17 PM
ImprezaRSX
10-01-2003 03:04 AM
Top
