Radiator removal diag
Car Info: subaru impreza 2.5rs 1998
Does anyone have a diagram on how to remove your radiator mine is cracked
on the plastic and 200.00 in labor or more is not in my budget.
Im going to check that out right now thanks
I live in Atlanta Ga now and I cannot find a used one
does anybody know if there is a comparable replacement for
a 98 rs radiator.
a 98 rs radiator.
to remove the radiator:
Step 1: empty the radiator with the radiator plug on the bottom of the radiator.
Step 2: remove the hoses, bottom, and top, and overflow
Step 3: remove the top bracket
Step 4: remove, if applicable, the underside plastic tray
Step 5: unplug the electric fan motors, usually two
Step 6: pull that sucker out
Caution: when putting new radiator fluid I would recommend using Subaru factory fluid with conditioner. Make sure you "burb" the radiator so that you don't have air line bubbles. Subaru's are a little harder than most.
Thanks thats whats up I will hit up your directions as soon as I find a another radiator
I recommend buying a Koyo all aluminum radiator. You can find them in some online vendors or even ebay. Subaru's oem radiator w/ the plastic top is really cheezy and it's only a matter of time before it leaks again. Might as well spend a little more and get an all aluminum radiator. The Koyo quality is superb and made in Japan.
Island Style
Hawaii Classifieds
05-12-2010 05:41 PM
sneakywrx
08-14-2007 01:43 AM
DetailAddict
05-03-2007 03:08 PM
