Instruction for key hole swap?
Car Info: AP1 S2k
Get needle nose pliers and remove C-clip behind the lock and the lock should slip out easily. Bring a mag stick with you just in case the C clip slides into the inner of the deck lid, so you can pull it out easier.
To install just slide the lock in and mount the C-clip and your done.
Heavy Dan
02-05-2005 12:48 AM
turbo_j
06-13-2003 12:05 AM
