Installed aftermarket DP with flat flange..stock cbe with doughnut flange...leaking?
Car Info: subaru
So I installed my DP with a flat flange. It doesn't mate well with the stock doughnut flange. Right now I just have a doughnut gasket in place and wrenched the hell out of the two bolts.
Fired the car up and I hear whistling.
I think I might have a leak coming from there.
Any ideas on how to make this a better connection?
first turbo car, first dp mod.
that might just be how it sounds
put some soapy water on it and see if you can detect the leak
when i put on my titek DP, it sounded like a leak but it wasn't
just the sound of the new DP
good luck
good luck
If you want to make the connection better then you should get a 3 inch cat back to mate up with a 3 inch dp.
medicSTi
05-26-2008 03:23 PM
