how to disable driving lights on 05 wrx
Old 01-26-2009 | 06:19 PM
duberx's Avatar
Car Info: 93 extra slow L
hey i was woundering if anyone knew how to disable daytime running lights on an 05 wrx
Old 01-27-2009 | 12:57 AM
DemonPossessed's Avatar
Car Info: 05 wrx
there is a yellow plug under the passenger side dash. all you have to do is unplug it.
looks like
http://forums.nasioc.com/forums/show...running+lights
Old 01-27-2009 | 01:37 AM
JourdanWithaU's Avatar
^ What he said...
I was expecting to read about a bunch of seatbelt clicking and e-brake pulling and key turning.
Old 01-27-2009 | 04:27 AM
duberx's Avatar
thats it omg wow thanks a lot i would have never thought it would be that easy
Old 01-29-2009 | 12:23 AM
Car Info: 05 wrx
yeah surprisingly so. i had to disable mine when I installed sti headlights in my wrx
Old 01-29-2009 | 04:15 AM
duberx's Avatar
looks like
hey i notice that it is on an 06 is it the same for 05
Old 01-29-2009 | 05:41 AM
If you check a couple posts down on that thread it says that the same process will work for 05.
Old 01-29-2009 | 06:37 AM
duberx's Avatar
o ic thanks lol maybe i should take trhe time and read hahaha im dumb thanks guys
Old 02-05-2009 | 11:35 PM
soobedup's Avatar
Car Info: WRX wagon 2006
There's another spot inside the engine bay. I'll upload pics tomorrow morning.
Old 02-06-2009 | 05:31 AM
Mulder's Avatar
Car Info: 02 WRX WRB
What's in the engine bay is just the dropping resistor, disconnecting it will interrupt the ground path for the DRL's and turn them off IF your lights are stock. However this does not actually disable the DRL control module and it will still be applying power to the headlights, so if you modify your lights with HIDs or aftermarket headlights that use direct grounding, the DRL function will return. Unplugging the main control module by the glovebox WILL eliminate the DRL system for good.
Old 02-06-2009 | 11:42 AM
soobedup's Avatar
Here is the module to unplug to get rid of your daytime running lights. When I had my KLight HID installed I had this unplugged.
Attached Thumbnails how to disable driving lights on 05 wrx-drloff1.jpg   how to disable driving lights on 05 wrx-drloff.jpg
Old 02-07-2009 | 09:05 PM
Mulder's Avatar
That is the dropping resistor. Re-read my post above to see why it's not a good idea to just unplug that without unplugging the main control module inside the car, especially when adding HIDs or other aftermarket light setups.
Old 02-07-2009 | 10:44 PM
soobedup's Avatar
It worked fine on my lights. No need to unplug anything in the dashboard. I have KLight HID's too.
Old 02-08-2009 | 06:00 AM
duberx's Avatar
ill just try both ways it dosnt hurt tanks for all the help
sUpRSikwRx
12-07-2008 12:17 AM
SpeeDyScooBy
07-22-2005 10:58 AM
dub81
07-09-2005 02:24 AM
BoardRider
01-09-2003 04:42 PM
BoardRider
01-07-2003 02:15 PM
