help with a/c idler pulley
if someone can get me a good picture or a diagram of the idler pulley and the bolt that attaches the idler pulley for the a/c that would be awesome!
thanks
ryan~
thanks
ryan~
Could be a bad high pressure cut out switch. You a/c clutch coil could be going bad/disconnected. Might have a short in the HVAC controls. You can try jumping the low pressure cut out switch to see if the clutch will kick on.
The bolt that goes through the pulley locks it in place on the sliding adjuster bracket. If the long adjuster bolt is turned without first loosening the pulley bolt, the adjuster will not be able to move and the plastic part the adjuster bolt goes through will then break. This is a very common mistake people make when attempting to adjust the belt.
![Lol](https://www.i-club.com/forums/images/smilies/lol.gif)
Brfatal
10-20-2003 10:31 PM
