Engine Oil Change DIY
Machine Zealots - Subaru STI Engine Oil Change with German Castrol Syntec - YouTube
Hope this helps anyone who needs it =)
Afterthoughts and other things can be found on the blog:
Machine Zealots: Subaru STI Engine Oil Change
Wow, that's pretty amazing. How did you go about draining the oil? I personally don't mind removing the skidplate, doesn't take long anyways, but I'll definitely check out the clearance the next time I get under there.
Still suprising to me
If in doubt, FLAT OUT
There is a weep hole in the tray that the oil from the funnels into, which actually makes it quite simple. The oil drain plug isn't covered (at least on 04 it isn't). You have to angle your arm in and have a filter wrench that fits, but it isn't that hard.
evsoul
18
10-26-2006 12:44 AM
tekgnosis
14
09-07-2006 05:21 AM
