Belt tension
Car Info: 07 Impreza 2.5i SE Sedan
Belt tension
OK, just wondering about the perrin pulley install. How are you supposed to tell when you have the belts tensioned right??? I watched the install video, and they just say something generic like "make sure you are happy with the belt tension"...well WTF does that mean? Thanks in advance.
Car Info: STI 2006 White Stage 666
Just tighten it till there is no slack in the belt and the belt does not slip. If the belt slips then tighten it more.
The only way to do it exactly is to a specification is to get a special tool like this: http://www.etoolcart.com/index.asp?P...OD&ProdID=1061
Car Info: 02 Silver WRX sedan. Eibach springs, Blitz NUR cat back, Rota 17" Attacks, Cobb AccessPort/DP
Push on the belt
There should be about 1/4 of an inch slack in the belt when you push on it half way between the pullies. Other than that listen for squeeks, if you hear them, tighten the belt a little bit.
Heedz
03-15-2015 04:32 PM
andyhidley
10-27-2005 07:11 AM
Digital 9ine
09-22-2005 05:39 AM
