Wtf!!! Need Help!!!
Car Info: ghey e-rights activist
Wtf!!! Need Help!!!
here's the story, my car is usually at 17psi, today i was driving it and had trouble getting past around 8 psi and the car started jerking. I popped the hood and noticed one of the vacuum lines was shot. (the one connecting the boost controller to the selenoid...i think...it's the little silver cylinder in front of the turbo) I took it for a drive and it boosted a little better but still jerked around 14psi and wouldn't go above 5k rpm. I'm completely stumped. Today i got my CEL fixed at Vakamon. They used a spacer and reset the comp, but i don't think it's that. There wasn't a high pitched noise coming from the turbo and no smoke. HELP!!!!
my mods are VF39, FMIC, 3 inch exhaust, intake, STI pinkies, and i believe the car came with a tune from a plug in. Thanks for the help.
sounds like you melted a hose and your car went inot limp. have you reset the ecu since? that lil silver thing your talking about, do you mean the wastegate?
yes, i meant the wastegate. Since i have owned the car, i haven't reflashed or messed with the ecu. The shot hose has been replaced. What do you mean, my car went into limp?
