where to get REDLINE GEAR OIL
Old 10-11-2006, 01:46 PM
BattleD01's Avatar
Location: battling between the mountain munstas! Kalihi
Car Info: GC8 Type-R, BH5 Wangon Gen3 and 05 SV650 Naked!
Question where to get REDLINE GEAR OIL
hay guys where can I get RedLine Gear Oil?
BattleD01 is offline
Old 10-11-2006, 02:04 PM
Island Style's Avatar
You're in Kalihi aren't you?
I think I've seen you car on the Likelike...Dk Blue GC8?
Anyhow, I picked mine up at Redline Automotive on Waiakamilo road...just went there to pick up my accessory and ac belts for my STI...nice guys. It's across the street from the Chevron gas station...near the corner of King St. and Waiakamilo...
Island Style is offline
Old 10-11-2006, 02:16 PM
BattleD01's Avatar
Yeah I live in Kalihi Valley and I drive up likelike hwy alot but my car is a Seafoam green color.
ok im going ther today I hope they have some gonna get RL gear oil. if they dont have then Vakamon is my last resort ^_^'
Old 10-11-2006, 02:18 PM
I think Vakamon picks theirs up there anyhow...
Yeah...they should have it...good luck.
Old 10-11-2006, 05:27 PM
BattleD01's Avatar
ok I think I got the wrong gear oil I got 75w90 High Performance Gear Oil. I saw the shockProof oil but it never have any 75w90 on it so I never get it cause I was thinking it was some kind of additive or something like that.... can anyone help me on this RedLine GearOil stuff? thanks.
Old 10-11-2006, 05:46 PM
Raudi's Avatar
You can get redline oils from RedLine parts.
Raudi is offline
Old 10-11-2006, 05:52 PM
oldmansan's Avatar
Yeah,
I can help. In my humble opinion, the Redline shockproof transmission and rear differential for my 2002 WRX made no difference. I was expecting a difference, but noticed nothing. Check the transmission forum on NASIOC, there's a thread there where the hot ticket seems to be some pricey dino gear oil (or Uncle Scotty's speciaql formula). I use Redline engine oil religiously, so it's not like I'm dissing Redline, but the tranny/diff synthetic oil didn't impress me. It isn't cheap either.
San
oldmansan is offline
Old 10-11-2006, 08:42 PM
BattleD01's Avatar
so does anyone know if its safe to use redline 75w90 high perormance gear oil on my diff?
Old 10-12-2006, 08:18 PM
BattleD01's Avatar
Old 10-13-2006, 02:51 AM
darksurfer81's Avatar
Car Info: 2001 BRP RSTi
Im pretty sure it is becuase Im getting ready to change my diff/tranny oil pretty soon and I talked to Ryan at Vakamon about it. He reccommended Royal Purple or redline 75-90 for the diff and Royal Purple MT fluid for the tranny. Hope that helps.
darksurfer81 is offline
Old 10-13-2006, 09:35 PM
joejoe69's Avatar
Car Info: 2015 CWP STI
Ey Ryan, how's your starter. Treating you good?? Hah-hah!!
joejoe69 is offline
Old 10-13-2006, 10:31 PM
BattleD01's Avatar
yeah why? my starter is just fine.... why is there suppose to be a problem? nah nah its good starts like a champ hehe... finally you join the club Joe so hows the project going for you?
Old 10-13-2006, 11:16 PM
shaggadelic's Avatar
Location: buying a house in hawaii is harder then it looks
are you talking about blazerwrx???? that ryan??? he was the one that needed a starter??
shaggadelic is offline
Old 10-13-2006, 11:29 PM
iNfEk's Avatar
Location: Boostin' troubles away - 4EAT Memories 12.87@103.2
YES, you can safely use that oil in your front and rear differentials. Since you have a manual transmission you should only have 1 fill plug. Your front differential and transmission share the same fluid. Make sure that you add the proper amount of fluid. DO NOT over fill (and obviously do not under fill) your transmission / front differential.
your rear differential will have 2 drain plugs which can be removed by using a 1/2" drive ratchet or a 1/2" drive breaker bar.
You will need to remove the lower drain plug first to remove the fluid. After it has drained, you will need to put that drain plug back in securely (do NOT over torque). Then remove the top plug to fill it. on the WRX/STI you need to fill it until fluid start to drip out of the top hole (make sure you read the capacity amounts though) then seal it back up.
You should have done a search on this. other people including myself has posted things about differential fluid changes...etc. before
you should also look at the impreza transmision section.
Jon
iNfEk is offline
Old 10-14-2006, 12:22 AM
joejoe69's Avatar
Unhappy Project RA postponed
Like I said, I dropped out for a while only because I sold my other GC and been busy working. Now I'm back starting all over again. Yeah so I can't do the RA for now, me and my son got really sick and we went to the ER. Some virus going around (wash your hands all the time guys). So we got medical bills to cover and the RA needs to sit aside, if not, I'm gonna have to turbo my 1.8L. Gathering some resources right now and trying to boost on a budget as well. For now, I'm just doing exterior, you saw my car, it needs a paint job!!! It looks like a Tercel...runs like one too...HAH!
joejoe69 is offline
Quick Reply: where to get REDLINE GEAR OIL
