stage 6 engine???
Old 02-24-2005 | 04:02 AM
sakebomb's Avatar
Car Info: 2004 WRX Wagon JAVA BLACK PEARL
stage 6 engine???
does this thing come fully assembled? just bolt on to tranny? or am i misunderstanding.
http://store1.vividracing.com/catalo...b3f78d2edc7904
Old 02-24-2005 | 11:42 AM
silver satin's Avatar
What ever you do do not buy anything from Vivid they have known to be thieves. It dosen't say anything about heads so not sure if it comes with them or not and thats kind of expensive..
Old 02-24-2005 | 12:01 PM
WRX-Zero's Avatar
Car Info: Justy
Vivid Racing = MUCH SUCK!
Old 02-24-2005 | 12:23 PM
luktang's Avatar
Car Info: 04 PSM WRX
Yeah, stay away from Vivid. I heard countless horror stories. Just go direct to Axxis' website and inquire about the Stage 6 if you're really serious.
Old 02-24-2005 | 02:20 PM
namakemono's Avatar
Car Info: gc w/ neons and a wrx that needs neons
another person wanting to experience the great customer service of vivid. maybe you'll be the lucky one and get your product?
Old 02-24-2005 | 03:13 PM
kidatari's Avatar
Car Info: Rust and Salt
If you're looking for a built engine, check out Crawford Racing or Axis Power Racing. Both are proven engine builders.
Old 02-25-2005 | 01:27 AM
oldmansan's Avatar
Uuhhmm,
that motor is from Axis Power Racing. Just a suspect middleman selling it.
San
Old 02-25-2005 | 03:59 PM
Chibby Goku's Avatar
Car Info: Vakamon WRX
Yup yup, that's an Axis block. Seems like no one has noticed, but that is a genius method of holding the sleeves in place. Call them direct.
Crawford also makes awesome motors. They have a proven block at PR
Also, SYC (Santiano, Yanes, Calavera) Systems has a project with the 2.5 STi block; we're sleeving the block and further closing the deck for added support. The project is currently on hold until we return from Iraq. We'll also specialize in ej series engine and drivetrain swaps.
Old 02-25-2005 | 07:39 PM
gdogg's Avatar
Car Info: 1973 Huevo Ranchero
isn't the semi-closed deck to help cooling? so if you close the deck(for added strength) how much effect you guys think it will make(if any)? having that, will it allow for much higher boost?sounds interesting. don't mind me, i'm no mechanic and i'm definitely a nOOb in this area.
Old 02-25-2005 | 08:57 PM
Yes and yes. We're not completely closing the deck; we are adding supports to keep the sleeves from shifting. Vibration is more apparent up top of the sleeve than it is on the bottom. The supports will need to have the same characteristics as the block due to thermal expansion.
We are currently eyeballing the GT42R for the project. If it handles the boost, I'll let you know.
Old 02-28-2005 | 07:44 PM
Also, just to give you an idea of how much we'll actually close off, look at the cooling passages on the heads. We plan on placing the supports on the areas that don't cover the passage ways. This way, there will be no cooling restrictions to the heads.
KTW
07-12-2004 08:33 PM
casualsurfer
05-03-2004 04:24 PM
Cend_wrx
04-05-2003 01:03 AM
mattr762
03-26-2003 12:47 PM
pillaka
29
12-01-2002 02:14 PM
