Rattling noise from front suspension
Car Info: 2005 WRX
I did a search on the various Subie forums and didn’t find anything conclusive; also, though I’m fairly comfortable with engine work, I know pretty much zero about suspension, so I have no background for this type of problem.
Anyhow, my car has around 66k miles on it and in the last few thousand miles I’ve noticed a rattling sound coming from the front of the car. It’s a rattling, clunking noise, like something loose, that I hear when I run over rough pavement. It doesn’t seem to be affecting the handling nor do I notice anything through the steering. It also seems to have gotten worse over time, but that could just be my imagination.
Based upon this simple description, is there something obvious that I should fix or look at? If not, what suspension components should I check and how would I know if I have a problem? Could any of these potential problems lead to sudden and/or catastrophic failure if not addressed? Thanks, as always, for your time and advice.
I had something like this on another car, took me forever to find - A hard fuel line had popped out of a clip on the firewall and was rattling when over rough pavement but of course it didn't look out of place when looking in the engine bay... though this won't be the answer you want, definitely finger trace all lines running from firewall to motor and anything along a body panel in the engine bay to see if it's come loose or missing a clip.
It's hard to diagnose w/o hearing it in person but does it sound like it's coming from a specific corner? is the rattle intermittent or constant at speed? does it sound like metal or plastic oscillating - and you mention clunking, does it clunk a few times in unison with the bumps you travel over?
Car Info: WRB Wagon
i get a similar noise from the front right of my car.. granted i have a torn axle boot but i doubt thats the reason, ive had lowering springs on my car w/ stock struts for about 50k and i think thats the culprit(wearing down the ball joint or other bushings etc.), i've heard a few other similar scenarios, i get clunks all the time as well on my 05 and i know of many others
can you describe the noise more? more of a clunk or a clicking?
When I was working on this ford earlier a part of engine removal was loosening the top nut on the strut. Dunno why but manual said to so I did. I forgot to tighten this when finished and heard a rattle/klunk. Tightened it back up. Noise went away. CAREFUL as if in the center of the nut is an Allen spot you are supposed to prevent that from spinning when you tighten it.
If they are coilovers mine had a rubber spacer that degraded and came out this causing clunky/ rattle.
Car Info: 2005 WRX
Thanks for all the suggestions, I'll jack up the car and look around to see if there is anything obviously loose.
The noise happens when the road is really rough, so the suspension is bouncing up and down a lot, during a steady cruise, not under braking. The worst is when I leave my house in Village Park, the main road through there is all bus' up and the suspension rattles quite a bit. Sounds like someone shaking a box of rocks when it's really bad. Not really a sharp metallic sound, more like a damped metallic sound, if that makes sense.
loose fusebox or similar? depending on the sound you can imagine the size of the object banging around... box of rocks makes me think strut top hat bushing (if there is one - on my cusco camber plates there was a bushing at the top that only make noise when the strut was really flexing at speed)
Car Info: CGM Crumpled Beer Can
I'm with Bushflyr, add "endlinks" for things to check first. The stock ones give out and start causing all kinds of noise.
Top hats also could be dried up and making noise as well. Which makes sense when it's only in "rough" spots.
Best of luck, that can be a maddening task.
Car Info: 2005 WRX
Update: I tightened the top strut nut the best that I could using a pass-through socket set (like the one pictured below) and an Allen-head socket on a breaker bar. I also tightened the nuts on the strut tower as well as the nuts/bolts on my 3-piece strut tower brace. I then jacked up the car and shook the tires and visually examined the suspension, but there was nothing that looked broken or loose. I tried shaking various suspension bits, but nothing moved or wiggled. I did notice that my oil pan drain bolt was a little loose, so it wasn't a total loss.
Anyhow, the front suspension is still rattling/clunking over really rough pavement, any other suggestions?
