Race w/ or w/o check engine light
Car Info: 2004 subaru sti
I have a check engine light due to a cel throwing because of my invidia dp. When I go to the track should I clear it w/ the OBD II scanner prior to racing or leave the check engine light?
Pr0n King
Car Info: Turncoat Turbo
Leaving it is fine.
__________________
__________________
What would A/F ratio have to do w/ the CEL?? you know what im saying dude. Listen to us and you'll be fine
Pr0n King
Is the DP catless? If so - that's what you're smelling. Installing a DP isn't going to make your engine run richer (that's controlled by a closed feedback loop using your oxygen sensor for input and injector pulsewidth for modulation).
The O2 sensor in your downpipe has nothing to do with that closed loop circuit, it just monitors catalytic converter efficiency.
__________________
__________________
06scooby
10-15-2006 11:11 AM
rash
05-17-2003 01:32 PM
