oil temps
Troll
Location: ***10 SEC CLUB*** 10.8@128mph w/clutch issues
![Thumbs up](https://www.i-club.com/forums/images/icons/icon14.gif)
I just did a search, hopefully this helps...
http://forums.nasioc.com/forums/showthread.php?t=380949
http://forums.nasioc.com/forums/showthread.php?t=375043
http://sma-www.harvard.edu/private/memos/115.html
http://forums.nasioc.com/forums/showthread.php?t=340253
http://www.wrxtra.com/ scroll thru these set-up and read the warnings, notes etc...
Typical gauge readings: This will give you a good baseline, to know when something is wrong...
Oil Pressure (cold): 100 PSI or more
Oil Pressure (hot) : 25-30 PSI Idle, 80-90 PSI Max
Oil Temperature (HOT) : 180-210 normal operating range
AntiochCali
09-29-2004 01:54 PM
AntiochCali
08-17-2003 11:59 AM
