need help on ur opinion
Old 08-06-2008, 01:37 AM
perky808's Avatar
Car Info: past 06 WRX, present 08 STI
Thumbs up need help on ur opinion
i'm debating if i should get the a-pillar or the clock cluster thing for the gauges... which is better?
perky808 is offline
Old 08-06-2008, 02:29 AM
june.rs's Avatar
Car Info: 07 pearl white wrx
go for the clock
june.rs is offline
Old 08-06-2008, 02:44 AM
rally_wrx's Avatar
clock=clean
rally_wrx is offline
Old 08-06-2008, 03:23 AM
dub81's Avatar
^^^ I agree with Mark on that one.. Center Pod that replaces the Clock is a much cleaner setup and plus it hides the Wires very nicely as compared to the A-Piller pods IMO. Or your could get the Zerosport Center Pod which allows you to keep your Clock in tact.
dub81 is offline
Old 08-06-2008, 04:22 AM
SVeXy96's Avatar
Car Info: 96 Subaru SVX LSi
Pillars look 2 fast 2 ***gotty to me lol
SVeXy96 is offline
SVeXy96's Avatar
WTF? I didn't know the f word for gay was a curse, but you get the point right lol
SVeXy96 is offline
Old 08-06-2008, 04:42 AM
uptheundagrnd's Avatar
Car Info: 08 Evo X
word, i vote for the clock pod... now if i could only afford a decent setup.
uptheundagrnd is offline
Old 08-06-2008, 05:03 AM
pwnx0rz's Avatar
Car Info: '02 WRX wagon
plus just imagine how hazardous the A pillar could be.
pwnx0rz is offline
Old 08-06-2008, 07:20 AM
96Imprez's Avatar
Car Info: 1996 Impreza Brighton bone stock sadly
idk, i kinda like the a-pillar look, wouldn''t it be easier to glance up at the a-pillar rather than over by the clock, i know its not much of a difference but it seems that it is just closer to glance up rater than over
96Imprez is offline
Old 08-06-2008, 10:56 AM
AngrySubyWagon's Avatar
Car Info: ghey e-rights activist
i have three gauges in mounting cups on top of my clock, so i retained it. I'm like an old man with my clock and my arm rest extension.
AngrySubyWagon is offline
Old 08-06-2008, 11:47 AM
rally_wrx's Avatar
depending on what you need...
i personally am not a big fan of gauges. i dont have to constantly see that my battery is 11.9-12.9 V. if you want something really simple, IMHO, just have what is important to you visible at a glance (boost (*mainly), egt, temp). otherwise, keep your eye on the road and not on the pretty colorful gauges (no punt intended).
for my other readings, i have a informeter set up by my fuses for all the OTHER important gauges.
then again, UP TO YOU> =D hope that helps
Old 08-06-2008, 03:56 PM
eRicaSWGN's Avatar
Car Info: 2006 OBP WRX Wagon & SGM 2.5i wagon
I agree with everyone else...
Clocks are cleaner. Gauges are more showy.
Just depends what you want your car to feel like.
eRicaSWGN is offline
Old 08-07-2008, 02:46 AM
perky808's Avatar
where could i pick up or order the center gauge pods?
perky808 is offline
Old 08-07-2008, 06:35 PM
BoOm's Avatar
Additional to the clean look the clock gauges provide, you will also replace the clock which is a very good thing considering that Impreza clocks break down within 5-6 years.
When mine stopped working after 5 years, I did a search around and found it was a very common problem with Imprezas.
The clock started acting weird flickering on and off and sometimes doesn't work. After a year of that happening, it completely broke.
BoOm is offline
Old 08-07-2008, 06:51 PM
Haole-Pino's Avatar
Location: "I am McLovin, The 27 yr old Hawaiian organ donor"
I recently had my Defi Center Guage Pod Installed with some Saga 60mm guages. (I originaly had white guages before, but I recently had them switched to red instead to match the STi cluster) Looks very clean and OEM'ish. I also have the A-Pillar guage pod (It's sitting at home, collecting dust) I tryed it out for afew days, but a honda drove by with the same "fast and the furious" setup as me, so I removed it as soon as I got home that day. Plus with 60mm guages, having them on the a-Pillar theres a contant "glow" on the left side of your field of view. It gets annoying.....
Haole-Pino is offline
Quick Reply: need help on ur opinion
