need help...
Car Info: past 06 WRX, present 08 STI
need help...
my check engine light is on also with the cruise thats keeps blinking... i tried putting stock sti exhaust on with the stock bov... and couple days is still on? i'm not sure wat to do... but not sure if its the motor or i need a cobb ap?... what do u guys think? thanx for the help if anyone knows?
Car Info: 04 sti now pulling hard but super greasy!!
mine has been doing that forever already!!!! fix would be to get an engine management system like the ap v2 that will help for sure the flashing cc light means your car is running in safe mode your probably pulling a p01420 code cat deficiency or a over boost code or secondary cat deficiency code to clear it for now just pull off your negative cable and hold down your brake pedal for 30 seconds then re attach your negative cable and see if the code pops up again....
unstble
03-21-2008 09:09 AM
resident smurf
05-30-2005 08:17 PM
Eggman's-STI
10-05-2004 10:43 AM
brucelee
05-28-2003 09:47 PM
