My GCs motor might be dead?
Old 07-20-2010 | 11:11 PM
BattleD01's Avatar
From: battling between the mountain munstas! Kalihi
Car Info: GC8 Type-R, BH5 Wangon Gen3 and 05 SV650 Naked!
Unhappy My GCs motor might be dead?
Ok I think my motor is all buss LOL
Eversince I got my bike 3 months ago I never realy started the car and now it realy runs rough.
It bogs out and dies can't seem to keep the idel...
Maybe now I have to start saving up for a new motor or just try to figure out what's wrong with this one.
I drove my uncle from the valley where I live to Farrington High School the bam... It started to bog then dies out
Anyone know what's happenin?
Old 07-20-2010 | 11:12 PM
sneezerboi's Avatar
Try fresh fuel and seafoam the sh*t out if your motor.
Old 07-20-2010 | 11:15 PM
4080wrx's Avatar
Sweet! time for a swap....
but seriously try what Josh said and it doesn't hurt to do a full tune up
Old 07-20-2010 | 11:18 PM
BattleD01's Avatar
I know I should try a tune up.
But if I do, do a swap then I might buy my friends 04 STi motor only and build it up on the side.
Sooo here's a question, how do u put fresh fuel when I have half tank?
Old 07-20-2010 | 11:23 PM
04sleeper's Avatar
get to suckin limp dick
Old 07-20-2010 | 11:24 PM
4080wrx's Avatar
siphon it out or there might be a drain plug on the bottom of tank. or you can just put some 92 in and run it till it is gone then fill up again.
Old 07-20-2010 | 11:28 PM
4080wrx's Avatar
oh FYI next time you decide to store your car for a long period of time fill it full of gas and buy that stuff (cant remember the name) that keeps your gas fresh. if you leave your gas tank half empty the tank will build up condensation and the water will mix with your gas.
Old 07-21-2010 | 12:47 AM
spinplay01's Avatar
From: Ice Palace...not the meth lab, the skating rink.
Car Info: 1995 dodge neon
i doubt it's your gas.
today's fuels have additives and ****.
You can let a car sit for a year and it shouldn't cause much of a problem.
If you want proof, I have a volvo s40 that I havnt started in over 5 months. I bet I can put a battery in it and it will start and run just fine.
My 04 wrx sat ungaraged for 9 months and ran just fine after.
Is your check engine light on?
Read the codes.
Old 07-21-2010 | 01:33 AM
houdni's Avatar
Car Info: 06 STi
+1 with spin....
I'd throw a scan tool to see if you can throw any codes...Im guessing itll be the maf..or idle air control solenoid...dont know what subaru calls it....maybe insuff. fuel pressure?...anyways....scan tool...
Old 07-21-2010 | 04:20 AM
joejoe69's Avatar
Car Info: 2015 CWP STI
Dirty MAF, IACV or TB, clogged EGR, dirty injectors, clogged fuel filter, plugs?? These are were I'd start if I had those problems. Possibly a vacuum leak too if idle is rough and dies. Try checking your vacuum lines if any are faulty. Save it before you really need to swap it out.
ronw
10-15-2013 11:42 PM
ronw
Wanted
10-10-2013 04:08 PM
05_WRex
12-28-2009 10:11 PM
revel
07-14-2005 12:10 PM
Subaruski42o
10-08-2004 04:22 PM
