Idle Problems
Idle Problems
Anyone know of different things that can make the idle go high and or fluxuate between 1200 and 1500 RPMs? I was thinking possible vacuum leak but I see no broken lines. Furthermore, my ECU has a problem I think cause a few months after the swap it would misfire on 1&3 cylinders and it would stop if you kicked the area where the ECU is, so I was thinking there was a wiring problem but I dont know much about the electrical system. Im gonna try to take it to Vakamon tomorrow so they can have a look at it, but if anyone here has any ideas or experience with a GC with a '02 WRX swap please let me know! Thanks in advance guys.
-TIM
-TIM
forgot what is called, i think it's IACV or something like that...it sits right around the throttle area...might wanna check that out...if this doesn't help, go to scoobymods.com and do a search there...
myself, including Jon(infek), and Jeff(wrxflip) that i know of has done it....as for me, it was part of my 30k service, didn't have to..but i did it anyway...the old one was in decent shape, so don't know if i could help you if it worked or not...it's only like $9 or so at Subaru...one of the ways you could tell it's no good, if you take it out and shake it and if the ball inside the pcv doesn't have that smooth flow, then go ahead and change it...when i compared mine with the old one, you could tell the difference ...hope that helps...
Originally Posted by darksurfer81
Yeah I just read about the IAC gonna try cleaning it if I can find it. The PCV is under the IC? As in remove the IC to get to it? IF anyone has done this let me know if it worked.
Location: Boostin' troubles away - 4EAT Memories 12.87@103.2
do not look for it with the car warm if you pull the wrong hose you could get coolant shot everywhere and burn yourself pretty bad (like i did).i thought i had the right hose and turned out to be the coolant line that goes to the TB.
thebing
16
07-21-2006 11:18 AM
rallied out wrx
05-28-2006 01:54 PM
grex767
05-27-2006 10:37 AM
Col. Smith
08-18-2005 01:41 PM
