How race gas help stocks STI's 1/4 times??
Car Info: '05 STI
Just wondering how my STI's improve by putting race gas and where I can get it?.>
I've heard theres one gas station here in hawaii with 104 octane.....I think its 76 station in honolulu...but I dont know exactly.....does anybody knows???..
Location: Ewa Beach, Hawaii...Current Best Time: 12.59 @ 107.48mph (108.47 best mph) in Hawaiis humid weather! w/ stock turbo&intercooler
Car Info: 2004 STi.....stock turbo/intercooler/cat-back, aftermarket intake/downpipe/piggyback
Ahhemm, I wouldnt put race gas on an otherwise stock STi, without being able to adjust A/F Ratio...and/or boost psi. Take it from me, Ive done it myself...I was running 13.3-13.4s ...bone stock on pump gas!, when I ran 100 octane , I ended up running 13.6-13.7s along with a 3mph loss in trap speed! Higher octane = more difficult to burn, but has more BTUs...a stock STi already runs too rich! I ran my Blue STi last week ....12.80, 12.87, 12.87 @ 106mph on 93 octane pump gas tune! I had bad 60ft times (1.8) because it drizzled a little, remember.
Angry Dan
Car Info: 05 Evo VIII
There is at lest 3 Sti (me being one of them) and 3 WRX HIIC owners w/ VERY lightly mod'ed or stock cars... that have ran better 1/4mile time and trap speeds by just using 100oct.
Originally Posted by turbocalculator.com
Compression Generates Heat
When air is compressed so that more air can fit in the same volume, its temperature is increased. This is compounded by the fact that the turbo is not 100% efficient and generates heat when compressing the air. Since the air is hotter, it is less dense, which means less oxygen is in the cylinder than if the air were cooler. This explains why a 14.7 psi turbo gauge pressure will not double the power of an engine. The heat also explains why an engine under boost is more prone to knocking (predetonation or auto-detonation). In order to cool the charged air, an intercooler or water/alcohol injection is often used.
Using 100oct will help fight predetonation which in turn...will make your ECM and use the aggressive map = you go fastAr.
But I've been out of the "Game" for a while...I may be wrong.
Well, mixed reviews....so its up to you to do what you think. Maybe I just ended up with a bad batch? at the time....perhaps? Or I just dunno what Im talking about, cause I can only run 12.65-12.8s on pump gas, and 12.5-12.6 on 100octane w/ a RACE GAS MAP on my piggyback ECU + downpipe, thats all....
Mach5 and a few others including me have the first batch that had the detenation problems so maybe the higher octane gas made a difference or OH god could it be a good driver behind the wheel who knows...And honestly if your into drag racing there are better cars than a Subaru the last thing a AWD car was made for was drag racing...
You can make 93 or even 94 octane by mixing a little 100 in with the 92.
This is what I do to run a 93 octane map, I basically mix 3 gals of 100 and 7-8 gals of 92 to make 94 octane (just to be safe). But I agree with it being meaningless on a stock boost car.
I would also recommend doing a search on octane additives. Alot of old skoolers in HIIC have user xylene or toulene as additives, staying away from bottled octane boosters. I myself have never done this since the station with the race gas is a mile from my house.
My $.02.
-What slows your car down? Pulled timing or too much fuel.
-What normally causes those two conditions? Knock makes a stock ECU divert to a lower ignition advance multiplier, ie it defaults to a lesser aggressive map.
I can't think of a condition where the stock ECU forces the mixture to be TOO rich. Many aftermarket ECU's/piggybacks come with pig rich fuel maps, but that's an existing condition not a reflexive condition like pulled timing.
-What effects do racegas have on an engine? More resistance to pre-ignition. Burns hotter.
I have never heard of any cases of misfire due to the use of race gas. I can't think of any reason at all as to why race gas would slow any car down.
