Help W/apexi Tt
Car Info: 04 WRB WRX
Help W/apexi Tt
i purchased an apexi tt and the harness for it and had pretty much no trouble installing it...i need help with a few things though...i couldnt figure out how to hook up the parking brake saftey and how do i make it so i can turn off my car and use my keyless entry to lock my doors? currently i cant lock my doors with the tt running...any help would be greatly appreciated!!
thanks
tim
thanks
tim
The
parking brake safety isn't worth hooking up. For info on locking the doors with the timer on do a search on NASIOC. I used to have the info, but it's been years since I needed it. Any good alarm shop can help you. If you're going to get an aftermarket alarm, you'll have the same problem. Basically the keyless can't arm (or an alarm) because it "sees" the ignition is on. To get around this, you can wire in a relay to prevent the keyless or alarm from "seeing" the ignition is on. You don't need a relay if it's just the keyless you're trying to access. Decide if you want an aftermarket alarm. No since fixing your problem twice.
San
San
Car Info: Rust bucketo
I think if it's just for the keyless entry, you'll have to cut one wire. You'll have to look around a bit, but it's bee done.
mr.sti wrote up a tutorial for an alarm install via a relay here, but it's also been posted a lot on nasioc; check for the username netZ.
If you're thinking of hooking up the parking brake kill, try seeing if you can hook it up to something else. The parking brake one will only prevent you, yourself from driving away with only the timer activated, as a safety feature. The wheel will lock. But uhh.. as far as a theft deterrent, the parking-brake wire won't be of much help, as most people already know TT's turn off with the parking brake, so they'll just keep it up a click or two. and the lease of their worries are the parking brake wearing out either
I was thinking the clutch switch, but I forget how the parking brake wire is triggered, is it a ground... shrug..
try using somethin like the door switch. those are usually ground. jus make sure ur door is open before taking out the key... I use the brake wire, i think of it as a saftey feature rather than a antitheft feature.
demonbugeye
Hawaii Classifieds
07-28-2009 03:10 PM
