Help Meeeee!!!!!!!!!
Car Info: 02 WRX
ok im kinda worried about this one.. every time my turbo kicks in it sounds like there is a screaming coming from underneath my hood. almost like its sucking WAY to much air. i dont really know what it could be. if you have any suggestions PM me or some thing. thanks - mike-
Location: Boostin' troubles away - 4EAT Memories 12.87@103.2
sounds like a leak from the up pipe to me that is if you have one. If not then one of your gaskets broke somewhere on the exhaust manifold to turbo
check your intake and see if any hoses popped off. also check the turbo inlet for leaks. worse comes to worse bring it out on friday and we'll look at it.
Definitely look around for any hoses that may have popped off. It's happened to me before, I had to tie-strap one of the hoses on to the nipple to keep it from slipping...
(heh, I managed to say nipple and slip in the same sentence...)
