Help: any power steering guru's out there
Old 05-04-2006 | 01:17 AM
motomech's Avatar
Car Info: the daddy van beatin da bass
Question Help: any power steering guru's out there
Ive been having trouble with my power steering and from what Ive gotten from the few people Ive talked is that there is air in the system or the pump is going out. I am looking for someone with the experience to help determine the problem or point me in the right direction to a reliable shop I was going to take it to the dealer, but they wanted $95 just to diagnose. If anyone helps me I'll provide lunch and some cash.
I.M. me or call me at 389-0271
Brian
Old 05-04-2006 | 01:22 AM
hayn_wrx's Avatar
Car Info: 02' wrb wrx w/ RGII
did u check ur power steering fluid and the lines also ?...i had the same problem for a few days outta no were i had no power steering..n e ways i jacked up the car and check all the lines and sure enough one of the nut's was a lil loose so it was leaking..problem solved...hope this helps
Old 05-04-2006 | 01:33 AM
iNfEk's Avatar
also depending on your mileage it might be time for a power steering fluid change
Jon
Old 05-04-2006 | 01:53 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
What year is your car? How many miles?
You really gotta provide more info if you need help from "gurus"?
You might as well just say "I have a problem and I need help..." That is just as good.
Old 05-04-2006 | 02:12 AM
shaggadelic's Avatar
if u have an upgraded turbo the line could be resting against the turbo and melt. i caught it on mine and also a friend had his melt on him while he was driving. u may have a small leak. just guessing b/c not much info so going on my experience with it
Old 05-04-2006 | 02:26 AM
motomech's Avatar
sorry, its a 2000 forester withe about 76k. I check for leakage(Breifly) but found nothing, fluid level is full, although it acts as if low, jerking while turning left and right, but is fine when revving.
Old 05-04-2006 | 02:31 AM
ok throw my thought out i thought u were a wrx lol
wrx 03i
01-10-2011 05:27 AM
Latka
10-24-2006 01:37 PM
dyepball1
05-18-2006 11:23 AM
Toiletbrush
09-08-2005 01:58 AM
RussB
06-02-2005 06:27 PM
