Dual drilling brake rotors
Why not just get the correct Rotors? Besides the bolt pattern is the rotor the same thickness, the same size diamater? Are these some awesome aftermarket rotors that are just so bad *** you "have to get them drilled to work" vs getting some that work right out the box?
Car Info: Loading...
I believe you can pick up 04 STI rotors those are already 5X100 and your all set, i can see how if you already have a set of rotors, having them drilled "makes sense". Question though. Are they new rotors or used? have you thought about selling them and then pick up an after market already dual drilled pattern rotors or stock 04 sti front rotors.
Car Info: 99 M3,91 SSM Miata,00 CSP Miata,RX330 DD
I'm sure anyone who has a drill press could do it. It is something to be wary about though, as you're removing a lot of material from the face, and if it's drilled just a little offcenter, you'll have a massive wobble. I don't know of anyone who can balance it as well, and having an off balance rotor may amplify any wobble.
Can you use 04 STi rotors? They're pretty darn cheap on amazon... to be honest, it's probably just a bit more than if you found someone who could drill it correct.
New rotors. I'm just looking for a local shop that can do this. If anyone has experience with a shop, please chime in.
Have you checked out FastWRX site? They sell rear rotors already drilled.
I think you need to look in the mirror and repeat that to yourself.
I know what you said, obviously you are not understanding what I said. But for you to have this type of idea anyways..... kind of hints your intelligence and technical background.
Just buy rotors....... really though.
Also if you do these on the rear ones you lose your parking brake as the sti parking brake drums are larger.
These guys sell kits:
KNS Brakes
KNS Brakes
KNS Brakes
KNS Brakes
WRX and STI rear rotors have the same drum brake size.
