does anyone know how to bypass check engine light?
Car Info: 2004 WRX
I have a 2004 WRX. just installed the AEM short ram intake. drived it for couple hours then the check engine light went on. does anyone know how to fix this problem.
^^^ yea, what he said... if you are looking to get more air, even though you don't need it go with a Turbo XS short ram or something that keeps that stock intake size for the MAS. That way you will not be leaning out the car and firing the CEL
Actually,
I disagree with everyone. I had/have the AEM (not installed anymore) and got an initial cel, but after that was fine. Ran it for two years. Don't think anyone here will say my car didn't run strong with it. Reset your ecu. And contrary to posts, you won't run lean with it, unless the 04 is radically different from the 02. I know because I have a wideband 02 unit.
San
San
you are right it will not run radically lean, but enough to cause the CEL... you either deal with the light and hope it doesn't come back or you just deal with it daily. I am not saying it will lean you out to much, but on some cars it has cause some problems. Not many though.
Well,
I don't think you got what I said. I got an initial cel that went away, never to return. And I have a wideband unit that shows it didn't run lean at all. As said before, I have an 02, didn't have the intake/wideband on an 04. Wouldn't think it would be a huge difference.
San
San
I understood what you meant... I just think that one car might run fine with a CAI while another might not. I tried it on mine and it ran like crap. The CEL stayed on until I removed it. I now run and TXS short ram. I wish it would have worked on mine... nothing like getting cooler air into the engine.
split2nd
12-17-2011 12:06 AM
azer408
05-11-2011 11:27 AM
sanjosuby
04-05-2009 08:33 PM
sanjosuby
03-31-2009 05:34 PM
caterpill
09-12-2004 04:55 AM
