Cusco suspension (popping noise)
From: mr. police officer,im not as think as you drunk i am....
Car Info: 02 wrx
I've been on these used zero-2r's for about two years now. About a year ago it started to make a POPPING noise only when i turn the wheel 1 and a half or more cranks either way. I posted up a while back and several guys said i should tighten up the spring. So i did and it worked for a little while, then the popping would eventually come back. Now pop is a little louder and car pulls hard left!
Anyone else had this problem? Just change the top mounts? I'm hoping the strut isn't bent? How would i know this?
I also have zero 2r coilovers and I overtightened the camber plates and had the same problem. When I loosened one of the bolts, it was broken in half. I bought new camber plates and torqued it to 12lbs and that fixed the problem. I had a KAATOONK noise.
Word to this gentleman's mother. You should check the torque on all bolts associated with the coilovers.
