clunking sound?
Car Info: Black 2004 STI
clunking sound?
I put in a set of tein s. Tech on my 04 sti and now I hear a clunking sound in the front (not rear) when I go over any bumps. everything was installed correctly and is properly tighten, I double checked, and I cannot figure out where the sound is coming from.
anyone have this happen before?
any ideas as to what I should check?
thnx
thnx
thnx
thnx
you can put in a spacer under the nut that holds the tophat on and that should also fix the problem for good. i believe the clunk is usually from putting on shorter springs and there being play. hope that you get it figured out.
plac
08-27-2008 01:34 PM
darkonion
31
12-09-2006 07:44 PM
ChuiSti
10-09-2004 10:33 AM
