Check Engine light
Check Engine light
Hey there guys, I was just wondering if any got a obd2 code reader on them!! Reason why Im asking is because on my way home after todays meet, somewhere between pearl city and waipahu, my check engine light came on..My car is bone stock and was hopefully wishing that its just the o2 sensor or something simple to change out..No overheating,no oil leaks, oil pressure is constant, and no engine mods,etc...Maybe its because i never change my tranny fluid..Not sure.Could that be a possibility?? I remember my brother told me something to that nature. Well if anyone has a obd2 code reader, please let me know..
FYI:
2004 2.5rs
thanks,
walter
FYI:
2004 2.5rs
thanks,
walter
Location: Boostin' troubles away - 4EAT Memories 12.87@103.2
it would definitely NOT be your transmission fluid.
it's probably your car telling you that you have to change your spark plugs or it's telling you to stop driving me like a grandma... LOL
checkers does have free OBDII scanning but do NOT look at the description. Just look at the code that is read and look it up online or ask someone with the FSM to verify. They use a generic scanner that is not specific to any vehicles.
Good luck
Jon
- it could also be your 02 sensor but i wouldn't say that's a good thing since they are very expensive to replace.
Good luck
Jon
Thanks Jon and Beam!!!
Well, I just got out of the garage and did the simpliest check first.Which was to check my gas cover and I didnt tighten it to the point where it clicks so Im sure this was the root of the CEL coming on. So I tighten the gas cap, reset ecu by disconnecting the negative and positve battery terminals,pump brake pedal, put everything back but CEL didnt turn off yet.Ill have to go driving around and to checkers(on the safe side) to hopefully see the CEL go away. But yeah I know Jon, I hope its not the front 02 sensor heard it was like 182.00 bucks or something. Hope its just the spark plugs or a bad coil pack or something.
:sign0153:
Thanks,
walter
:sign0153:
Thanks,
walter
Aloha,
walter
well if it's obdii try check with another suby owner that has an accessport they might be able to read the code for you at least.
if not i'll see you at the next meet (hopefully) and read it for you. If i get a more stable schedule soon i'll start the meets again.
Jon
Jon
woohoo!!!:) BOO-YAH
Hey Jon, my CEL finally went off after another trip to home depot pearlcity..YAY:character0026: See at the next meet..I figure moanalua shopping center is convienent and neutral place for east and west iclub.
06scooby
10-15-2006 10:11 AM
rash
05-17-2003 12:32 PM
