(?) Alternative way of removing old gas out of tank?
Old 02-04-2011 | 03:46 PM
BattleD01's Avatar
From: battling between the mountain munstas! Kalihi
Car Info: GC8 Type-R, BH5 Wangon Gen3 and 05 SV650 Naked!
Im not sucking it out haha...
Old 02-04-2011 | 03:52 PM
1JavaBlk_in_Sac's Avatar
Car Info: $2000 hawkeye
there should be a drain plug.....somewhere....
Old 02-04-2011 | 03:53 PM
GD916's Avatar
Car Info: Wrb bugeye
Siphon hose.
Old 02-04-2011 | 04:13 PM
VRT MBasile's Avatar
Drain plug or disconnect the fuel pump (thats what I had to do on my old benz)
Old 02-04-2011 | 07:03 PM
ds baruuuuu's Avatar
Car Info: 5.4RS
easiest way is disconnect the feed line to the fuel filter and rout it to a gas can turn the ignition on and let the stock pump do the work. next is find an old fuel pump attach some hose remove your pump and stick hose in power up with 12v
Old 02-04-2011 | 08:39 PM
dub81's Avatar
Originally Posted by ds baruuuuu
easiest way is disconnect the feed line to the fuel filter and rout it to a gas can turn the ignition on and let the stock pump do the work. Next is find an old fuel pump attach some hose remove your pump and stick hose in power up with 12v
*like*
Double Phister
07-24-2005 01:00 AM
kidatari
09-09-2004 01:22 AM
andyC
03-31-2003 10:18 PM
