ABS Bleeding Help
Car Info: 2003 WRX
ABS Bleeding Help
Need help on how to properly cycle the ABS on my 03 WRX. Had a problem at last HulaX with brake line failing at the start of the run. I've searched and saw different comments on cycling ABS like fuse pull then replace after start, activating while on jack stands, activating on street the re-bleed, etc. Appreciate any suggestions from someone who has actually done this as I believe there is air trapped in the ABS. Thanks.
this order:
PF> DR> DF> PR
also i use atf super blue and they make 2 versions one clear and one blue. so you can tell when the new fluid has made its way there.
PF> DR> DF> PR
when bleeding the subys since they have abs(not as big of a deal) you need to go in the correct order or it will never work.... thats why you still have air in your lines go in the order i posted and you should be fine.... lmk if you need help
EDIT**
it is PF>DR>DF>PR you have to go in the right order.... its been a while since i had to do this so i re looked it up lol
http://www.scoobymods.com/bleeding-b...brake+bleeding
EDIT**
also the abs wont make a difference unless there is a leak there. also make sure you are tightening the nipples properly.
did you change your brakes?
Irish_car_B0mb
04-04-2012 02:26 PM
rex408
03-04-2007 10:27 PM
gqzboy
14
06-07-2003 07:50 PM
