1998 2.5 RS Automatic to Manual Conversion
Car Info: 1996 STI V3 Type RA
To all of the 1998-2001 2.5 RS ownders out there have any of you coverted your Automatic tranny to a Manual? I want to buy the RS that is in another post, but it is an automatic, and I was wondering if it is extremely difficult, to do. I definitly want to put a five speed on the car. Are the holes for the clutch and everything already cut if I pull up the carpet in the Auto model?
the holes are there but blocked off you need the ecu,trans,pedals,clutch master and slave,cluch and flywheel,rear end ,rear subframe,your front shafts will workbut you will need the rear(of course)..you also need to change the fuel tank so in my opion just find a 5spd
the ecu needs a signal fron the nuetral position switch from the auto you can fool it by grounding the wire but then you can start the car anytime you turn the key without in gear so you dont neeeeed to but for saftey i would wait i was wrong about the fuel tank i was thining fwd to awd as the front dont have a hump(hehehehehhee i said hump)for the rear drive shaft so you dont need it hehehehe if you get it pm me cause i gots a 5sp trans and rear end from a 01 give me 200 and its yours
DiS oNe GuY
Cars For Sale
01-03-2008 05:00 AM
DiS oNe GuY
12-20-2007 10:51 PM
bicanek
01-04-2006 05:11 PM
