throttle body's and fuel pressure regulators
Hi everyone. My friend runs a civic around town and bought himself a bigger bore throttle body. I was wondering if we can get those for our cars and if we can, what are the pros and cons. And as a side note, I was hoping someone could explain what exactly a fuel pressure regulator does and if it's worth putting in.
The fuel pressure regulator keeps the fuel pressure generally on most vehicles around 8-12psi. With aftermarket parts you can boost the fuel pressure to much higher levels.
This does a couple things. It produces a finer mist in the fuel dilivery for injectors, and also allows more fuel to be dumped in by the injectors.
I see. But with the fuel regulator, would the injectors be working harder, the same, or less? And combine that with the fact I'm still running stock injectors and a stock fuel pump. Should both of these things be upgraded together?
I can not tell you the flow rate of either your stock fuel injectors or your stock fuel pump. However, the most fuel pressure I have ran on my 2.2ltr Outback Sport was 70psi. This was done over and over again and was the 'fault' of running a 60 shot of nitrous pushing the fuel pressure up. This was on top of 5psi of turbo boost. I never had any problems with not having enough fuel.
For N/A purposes, I don't think you'll have any concerns of needing to upgrade your fuel pump or your fuel injectors.
boxstahboy,
i think you mis-interpreted. You will not need to upgrade your fuel pump, pressure regulator, or injectors until you get to the very limits of modification.
If you are running common bolt-ons you will have no need to upgrade these parts.
With nitrous, boost, or an all out N/A monster then you need to start researching them.
suby_dude
02-12-2008 01:28 PM
calisti
Subaru OEM Parts For Sale
09-16-2007 07:26 AM
cdaddy06sti
08-04-2007 05:10 PM
silverscooby
02-18-2003 07:29 PM
