temp gauge climbs to 'Hot' zone (was: Temperature Question)
Car Info: 2001 RS
So this is the first time I noticed this but when my car is at idle the temp guage goes all the way up to the H (heat) but as soon as I start driving the temp goes back to normal.
Anyone know what causes this? as I am clueless
Hurray, it's Ian!!
Car Info: 2002 MBP WRX Sedan
you might be leaking radiator fluid and the only thing keeping your car from overheating is all the cold air hitting it while in motion.
get your radiator fluid level checked ASAP. if it's empty, fill it up, if it's full and your car does that...take it to a mechanic/dealer. or hopefully other peopel will have helpful input.
sounds more like your fans not coming on, at speed your fan shuts off because air is moving through your radiator cooling it, when stopped at idle your fans come on. let your car warm up parked then pop your hood and see if your fans comes on. and check your fuses!
iClub Silver Vendor
Car Info: 2005 LGT wagon
Without looking at the car it's impossible to say what's causing your problem.
If the engine is stone cold...overnight cold...how long at idle does it take to reach H?
Did you check the coolant level?
Could be:
1. Bad gage and/or wiring.
2. Thermostat is bad.
3. Fans are bad.
4. Head gasket(s) are bad.
5. Clogged radiator.
6. Water pump is bad...not likely.
Could be:
3. Fans are bad.
Car Info: '03 WRX wagon, faster than walkin'
This has happened to me twice - exactly the same symptoms.
The first time my radiator was broken, there was a micro hole in the plastic part that couldn't be seen, but when the system pressurized, it would leak coolant.
The second time it was my water pump - just failed.
My neighbor also had the same problem once, it was a clog (kink) in the radiator hose.
Good Luck - fix it asap, cooling is very important for turbocharged cars.
Car Info: 2001 RS
Thanks for the replies guys, but yea I was driving around running erans and i stopped by my pad to run in and grab something and by the time i got back which was like a few minutes the temp was all the way up but as soon as i drove off it went back down, btw I have an 01 RS if that helps, also I do hear the fan while idle'ing and on my driveway I don't see any symptoms of leakage, so I'll take a look at the hoses and fluids and keep ya posted...
Could just be a bad thermostat. Not sure how the subaru ones work but my old truck back in HS went through those quite often. Only like a $3 fix. If it is a bubble most shops can suck the air out through a suction pump system. Faster than draining and filling up again.
to see if there is air bubbles in the coolnig system. take off the radiator cap(make sure your car is cool!) then squeeze the upper radiator hose. if you see bubbles coming up from where the cap is, that means there is air in the system. Just keep squeezing the hose until you dont see bubbles anymore, and add more coolant.
My money is on the fans not working. Run your car at idle, turn on the AC, and see if the fans kick on. If they don't kick on within about 30 seconds your fans and/or fan relay is bad.
-Chris
-Chris
Former Sponsor
Location: 865 A Sweetser Ave.Novato, CA (new shop smell too)
Car Info: MY04 STi some call it a race car
I have an 01 RS if that helps, also I do hear the fan while idle'ing and on my driveway I don't see any symptoms of leakage, ...
Hope this helps,
-Adam
Just curious if you ever found the cause to your problem. I have a 03 wrx that seems to be doing the same thing. If I sit at idle the temp will shoot up to H and if i rev the engine or start driving the temp will go back down. I can't find any leaks, fluid is full, hoses look great. I'm thinking the thermostat is sticking in the closed position when at idle going through an open close cycle and once the engine rpm's rise the rise in perssure is enough to help it back open again. It doesn't do it all the time just once every other day or so. If it was a bubble i the system I'd think it would overheat at any time not just at idle.
