quick performance mods (intakes, chips, etc)
i want to do something to my 2.5rs, but i dont want to jeopardize the warrenty in any way... so i was thinking maybe a drop in filter, or something like that, or maybe a performance chip (if they make one)
thanks in advance for any advice
can't really get what you're looking for without voiding waranty.....i suggest buying something anyway, like header/exhaust and keep the stock one, then if you crash/give it back, you can just swap the parts and nobody knows it was there.
you won't get much out of a chip or drop in.....nothing for performance at least
yeah thats what i was afraid of :\
i have a 2003 2.5rs ( i need to make a sig on day)
on my old car i voided the warrenty so many different ways (i had a dodge avenger) they got mad at every little thing i did, and im to lazy to switch stuff back to stock... especially change the headers back hehe
im not looking for anything crazy, just a couple of extra HP, or at least sound like i have a lil more power
on my 02 rs, i added a cobb intake, scoobysport axleback, and custom midpipe these are easy bolt on peices that should make your car more driveable and will not void your warrenty. plus its easy enough to just throw the stock intake back on if you need to go in for warrenty work.
i also added the GFB pulleys - these are a little more difficult than simply bolting on or unbolting if i need to go in for work.
eibach prokit springs, cusco rear sway bar, cusco strut tower bars. you should be fine with simple bolt ons like this.
a chip will most certainly void your ecu warrenty and most likely everything else if you have a shady dealer because you have to splice into the ecu wiring.
take a look at the cobb intake and a cheap catback, or even just the axleback if you dont want to do the midpipe.
have fun
Pat
have fun
Pat
Well, I have a Ganz CAI, K&N filter, 20mm FHI rear swaybar, Whiteline rear diff lock kit, Stromung Catback w/ Kartboy Hangers, PROECM Chip, 1.19 lb crank pulley, Kartboy Shifter, Momo Airleather Shift ****, Momo Boot, Kuhmo Ecsta 712s, Hawker 13 lb battery, sparco pedals, and about 150 lbs removed from my 02RS, and its still not fun enough.. I plan on getting some Cobb Street Cams, Koni Inserts, Borla Headers, Random Tech Cat, Exedy 9 lb flywheel, Cobb Clutch, Cusco rear triangulation strut bar, bored tb, lightweight bumper beams, etc.. You also have to take into consideration how much NVH you'll be willing to stand, driveability, cost, etc.. I figure when I'm finished with all of the above, it will have cost a little less than a stock WRX, will be just as fast without any lag, will handle better, and will also be unique. It will also be very conductive to a s/c when its paid off
Re: quick performance mods (intakes, chips, etc)
People will quote laws and other stuff but what's important to know is that different dealerships interpret what voids the warranty and what doesn't. Even if they are in the wrong and your modification has nothing to do with a problem you might have in the future, they still can try to connect your problem with the mod(s) you have done. If you are willing to fight a dealership in this situation, just be careful in your modifications and be sure that it isn't likely to damage a part you may need warranted.
It may also be a good idea to talk to someone at the dealership(s) you intend on taking your car to if work is needed to see what they consider a modification that may void your warranty. Then you get to hear it right from the horses mouth. At least you'll have an idea on what they may or may not look for when servicing your car. Happy Modding!
the dealership near me is really mod friendly... but i think its becuase they can make mad money off of me installing the stuff for me to fit "warrenty" specifications or whatever
the dealer told me i could turbo my car and keep it under warrenty haha
i think im just gonna stick to some exterior mods and call it a day (for now) hehe
enigma9011
Hawaii Classifieds
04-09-2011 11:52 PM
MPOWERD
10-01-2004 02:41 PM
OakosAutomotive
Vendor Group Buys/Specials
11-14-2003 02:53 PM
