problem - fluctuating rpm at idle
So yesterday afternoon when I turned on my car my idle speed started fluctuating like crazy; from 1.7 K-> .8 -1.7. It did this once in the winter and stalled. Btw this is an automatic 02 RS - only modifications are ganzflow intake and eibach prokit springs
any ideas why? is this something I should be worried about?
Thanks all
btw also posted at the OTHER forum
Thanks all
you might want to check all conections from the plug wires to plugs and plug wires to coil pack terminals. make sure they're all corosion free. i know your car is new but better safe than sorry. bad plug wire equals a bad coil pack equals misfireing equals $250.00. what is bump anyway?
anyways a bump is the process of moving a thread back to the top of the listings - bumped up to the top
It's probably just a symptom of the intake you fitted...the car is reading a slightly greater-than-factory volume of air coming into the intake, and this may in turn "fool" the intake air temp sensor into reading a slightly colder air intake temperature due to slightly non-OEM exaggerated fluctuations in air flow, thus causing a slightly higher idle and idle-air-control response to certain "perceived" variants. I wouldn't worry about it unless it doesn't moderately correct itself over a period of a couple months...
the ganz flow you still uses the stock air box above the throttle body right? so fluctuating air pulses shouldn't be a problem. that only happens when you remove the entire stock intake including the air box up stream of the throttle body. still say check for corrosion at both ends of the plug wires, spark plugs and terminals on the coil pack.
Actually the 98 thru 99 RS used a MAF sensor, and after that the normally aspirated models use a MAP sensor which has a more difficult time compensating for greater volumes of air (why do you think the turbo models still use an MAF ?)...so perhaps this would add some additional information to your final conclusion...
