No Start After Rebuild, EJ251
Old 08-04-2009 | 02:04 PM
salvator_rizzo's Avatar
I just finished installing the motor back in a 2003 outback sport.
ej251 - New Rings, re-honed cylinders, new rod and crank bearings etc..
Automatic trans.
Engine rotated by hand (well wrench) with everything connected
When I went to start the car for the first time, the starter clicked once and then nothing happened.
The battery is fully charged and works fine.
I had the starter tested and it works just fine.
There was only 1 ground wire that was disconnected prior to the swap, and that's been installed correctly (off the battery cables to the starter).
From close inspection it looks like everything has been plugged in and is good to go
people at the parts store suggested a ground problem, but i can't think of anything else that I disconnected. I have gone through the engine bay a few times and I can't see anything out of place or missing
What could be wrong? Any ideas?
Thanks in advance; I need to get this thing running
Old 08-04-2009 | 07:59 PM
MonsterGC's Avatar
Car Info: 2000 2.5rs
so only clicks once? and just dead silence after?
Old 08-04-2009 | 08:02 PM
After the first click when you tried to turn it over it doesnt do anything... does it click once everytime you try and start it? Or it just clicked that one and only time?
Old 08-05-2009 | 09:21 AM
It was basically just one click when I turned the key. It sounded like the starter is trying to do something, but it only clicked that one time. It clicks everytime.
I actually figured out what the problem was. The torque converter wasnt lined up properly with the output shaft on the transmission (not sure how I was able to do that) and so the engine was not able to spin at all. Im going to work on it now to get it done right
Old 08-05-2009 | 12:03 PM
Well hopefully that was your problem. Good luck with it and let us know how it turns out
Old 08-05-2009 | 10:55 PM
pain in the ***, but I got it. something was just not aligned correctly so the starter could not engage. Dropping the engine back in tomorrow morning
Old 08-06-2009 | 10:03 AM
congrats
Elsyd
04-11-2017 12:29 AM
i<3dirt
10-20-2014 10:26 AM
DWNSHFT
01-26-2013 06:05 AM
wakaranai
04-05-2011 02:19 PM
salvator_rizzo
07-20-2010 08:51 PM
Quick Reply: No Start After Rebuild, EJ251
