Need help installing awd gas tank!!
Old 08-14-2006 | 08:12 PM
wal.lin's Avatar
Car Info: 01 RS BRP Coupe
Ok, so I just removed the exhaust, rear crossmember, heat shield and then the fwd gas tank but on my awd gas tank, I see that there is an extra hose as well as another fuel pump? or some sort of thing that has 2 wires coming out of it. I need to know what to do with these ASAP since I'm doing part one of the awd swap right now. Heres a picture of the 2 wires and the hose coming out of the spare fuel pump? 2nd picture is of the fwd gas tank (top) and the awd gas tank (bottom). NEED HELP ASAP!! Thanks!!!
oh and i'm super light headed from all the fumes from the gas
Old 09-30-2006 | 03:26 PM
awdslde's Avatar
Car Info: 1995 awd impreza
gas tank
this might be too late but,
the other pump is a level sensor which works in conjunction with the pump due to the AWD "saddle bag" gas tank. the 2 wires should be being plugged into the connector that is already plugged into the fuel pump { im wondering if you put the FWD pump into the AWD tank, looks it from the pictures, not shure. } which would lead me to the next about the hose, that hose should be connecting up the other pump. reply back if your still in need of help.
Ron
Krang
Hawaii Classifieds
06-18-2014 12:19 PM
Outkast_STI
11-01-2006 02:55 PM
kidatari
09-09-2004 01:22 AM
scobaru
08-08-2003 06:23 PM
Quick Reply: Need help installing awd gas tank!!
