The N/A 200hp Barrier thread...
NASIOC Slut
I'm dedicating this thread to what can be done after you have all the bolt ons possible for a N/A 2.5 (or other N/A motor)...
There has been alot of discussion about it before, and quite a few attempts at breaching 200hp with N/A Imprezas. It seems to me, as i'm sure it does to everyone, that after the bolt ons things start to get considerably more expensive and complicated, which is to be expected. However, it would be good to air out all of those possible methods and ideas about the subject...
250,000-mile Club President
Car Info: MBP 02 WRX wagon
It should only be a matter of getting a pair of ported heads with big enough valves and way stiff valvesprings, along with a big tall cam and some higher compression forged pistons, then a good ECU map to optimize the AFR's and ignition.
Build it to wind up to about 9grand and you should dyno well over 200 HP.
I wouldn't think it'd be too terribly difficult,
it certainly wouldn't be cheap,
just not too difficult.
You'll have over 200chp on stock heads/block if you get:
Intake
Pulleys
Header back exhast
Spicy cams
See here Matt made 151.1whp 5000ft elevation
http://www.wrxforum.com/cgi-bin/ulti...4;t=001250;p=3
Intake
Pulleys
Header back exhast
Spicy cams
Originally Posted by StrykerGod
What about a TSi turbo? It supposedly adds 56% increase in HP, I'm thinking of doing it to my 1.8L...
Originally Posted by QuadsquadWRX
if a 2.5rs has 165hp, then all you need is to chain up 35 horses to the front of that beast, and there you go man 200hp to the wheels and hooves. ROCK ON
what is the minumum, that needs to be done to reach it. that s what all of this is about? the most for the least, going big does not always mean better results. i used to sell snowboards and skis's i used to see this mentality all the time.
i want the stiffist carbon fiber board their is on the market, while you live on the eat coast and mostly ride ice so it kinda hinders you. i guess you have to ride a couple of different boards to see it(feel it).
what is the major components that need to be changed out, and i am ta;lking bolt on?
-equal length headers (i.e twe, cobb)
-hi flow cat or catless pipe (i.e random tech, stromung, custom catless)
-cat-back exhaust (i.e cobb, stromung, scoobysport)
-lightweight crank pulley or pulley set
-cold air intake (cobb, injen)
-cams (cobb, twe)
-little things like grounding kit, tb bypass mod,
-possible ecu reflash from I-speed (when it comes out)
these are a good start that should get you some great gains.
-cams (cobb, twe)
NA helpers:
http://cobbtuning.com/impreza/powerpackage3.html
http://www.xcceleration.com/engine-packages.html
My 00 2.5RS
Lt pulley Mr. Josh
Ganz Intake
Borla headers
Stromung SS header-back
My 00 2.5RS
Lt pulley Mr. Josh
Ganz Intake
Borla headers
Something Custom
