fuel odor, loss'n fuel econ., & back fires. help????????
Old 12-29-2004 | 08:44 PM
scoobie555's Avatar
00 rs, help please?????????? what could this be, evap canister, fuel pump, what????????
Old 12-31-2004 | 01:47 AM
scoobie555's Avatar
no cel, plug wires are cool fairly new.
Old 01-03-2005 | 10:04 AM
DreddRS25's Avatar
Car Info: BRP Impreza RS MY01
I'd check the fuel pump, fuel filter, and catalytic converter (02 sensor).
Major culprits
Old 01-05-2005 | 08:47 AM
If it were a MAF car, I'd say the MAF is bad. Since it's a 2000, I'm wondering if your MAP sensor is bad- same symptoms, running too rich without throwing a code. Your O2 sensor is probably a better place to start though- when they go bad, the car will run richer instead of leaner, for obvious safety reasons.
Old 01-05-2005 | 05:10 PM
scoobie555's Avatar
wouldnt an o2 sensor through a code thou???
Old 01-05-2005 | 05:20 PM
Not necessarily. If it's only a little bit bad, the ECU won't have noticed yet.
Old 01-06-2005 | 06:02 PM
scoobie555's Avatar
well cleaned my air filter, r&r'd the fuel filter and my fuel econ probs are gone and havent herd back fires yet, but fuel smell is still present.
Old 01-06-2005 | 06:03 PM
Check all your fuel connections VERY carefully. Every single one. If you have a fuel leak under the hood, it will eventually catch fire, and there won't be anything you can do about it.
Old 01-07-2005 | 07:12 AM
DreddRS25's Avatar
I'd also check where the soft fuel lines meet the hard lines.
I think there is a problem similar to this with WRXs.
Old 01-07-2005 | 07:29 AM
You may be thinking of the cold-weather fuel smell TSB.
Old 01-07-2005 | 02:17 PM
scoobie555's Avatar
there was a tsb on that ? so what is the fix?
Old 01-10-2005 | 08:59 AM
DreddRS25's Avatar
I think for the WRXs it was a matter of tightening the cinnection between the soft and hard fuel lines. (quick search I couldn't find the thread I read that in, if I do I'll post it)
