Custom Intake Manifold (gauging interest)
Car Info: 1998 Subaru RS 2.5 (soon to be N/A beast)
My professor and I are about to start designing and testing a custom intake manifold that will flow better for the 98-01 Impreza RS. I wanted to see how many people would be interested in something like that and how much people would be willing to pay. I know that the stock intake manifold is super restrictive and a ton of power could be freed up from a different manifold; this would be especially good for those who have some headowork or cams. The manifold will be a full custom sheet metal manifold. It will be designed and tested on my heads. We will be using the flow bench to do everything, so we will have real flow numbers, not just some shot in the dark about how much we think it will flow.
My professor that is helping me design this manifold is a designer for ford's engine race development stuff (SVT Focus, Contour, Mustang/Cobra, etc) and holds over 20 national and world titles with the engines he's built and designed. One engine that particularly grabbed my attention was the 1.6 liter turbo'd Ford Cosworth that put out 1000 horsepower and was still strong enough to race around a track for an entire season! (until it was banned) And that was back in 1989! He has all the tools and a state of the art facility, so this will be tested to the highest degree.
Please give me some feedback on who would be interested in this.
Thanks.
Nathan
Thanks.
Nathan
I would be interested. The engine would love less restriction. I think I am going to have my manifold subjected to a little extrude honing in the meantime. I will post the flow increase over stock manifold after completed. Are you going to work on a larger throttle body also? Proflow may start work on a larger throttle body soon per e-mail. Watty
interested
I'm very interested in your custom intake. I have a 99 2.5 rs and I really want an intake. Parently installing an aftermarket intake in a 99 2.5 is very cumbersome because of some kind of problem with the sensor (don't exactly know what the problem is yet). But if you can come up with a custom intake that will fit my car without any problems, reduce restriction and all in all MAKE IT GO FASTER............ i'm up for a new intake.
Hey Nathan,
I was thinking about this yesterday and I was wondering if you would be keeping the throttl body in the same location as stock so peoples aftermarket intakes would still work (ie: Cobb ntake which goes to the fender well). Just a thought.
You know I want one, preferably the second one out of production after yours . Ill be your ginuea pig to see the gains on a built motor, and what kind of a difference it makes in tuning my car so you will know what to look out for.
I hope you end up doing this!
Dan
Dan
triman i think yur intake problem is due to yur MY99. now this is just from a friend of mine who researched for his MY98 so i duno if its 100% (but he usually knows wut he's talking about). from wut i've heard the MY99 and older hav a different intake system from the MY00/01. the pre MY00's hav a problem with aftermarket intakes because the O2 sensors get dirty and break or malfunction. they fixed it in 2000. cobb has an intake that is made by someone (can't for the life of me remember) which maintains the stock box and a cleaner for preMY00's so that u keep everything clean and u maintain yur low end torque, which u tend to lose with a lot of aftermarket exhausts and intakes. NOW PLEASE if anyone knows that i'm wrong please correct me otherwise hope this helps. OH yeah and i would eventually be interested in a custom intake manifold!
Here's another thought we had
My professor and I were talking. He would like to get another ECU and wiring harness so we could run my engine on his engine dyno and that way we would be able to test the heads with the intake manifold.
We are also discussing making some kind of cold air intake system with a custom torque box and possible maintaining the stock air box from the fender. I think he would also be interested in offering a complete package. It would be ported heads, valve job, etc. with the cold air intake and the custom intake manifold. These would all be offered by my professor through his shop.
Also, my professor would like to get heads from a SOHC car. We are mocking up the intake manifold on my car with the DOHC and we will be mocking up an engine with a set of SOHC heads so that we'll be able to get everything perfect. Someone let me know if you can help me out with this little problem of finding some SOHC heads. They could be completely bare or cracked or blown up, it doesn't matter, we just need them to fit up the manifold.
One last thing. My professor and I also discussed the possiblity of making dual intake maifolds. He said that it will make a much more effective flow to have 2 seperate intake manifolds. We might experiment with the possiblity of doing this with a custom torque box that would maintain the stock position of the air intake system. We'll see how that turns out, I'll let you all know.
Please (everyone) get back to me if you have any ideas, criticisms, parts, etc.
Thanks.
Nathan
Thanks.
Nathan
is it possible from wut u think u'll b doing with either the single or double intake manifold to keep most of yur stock parts where they r? or is either way going to change locations and even hav a need for custom intake parts to be utilized?
Stock Location (hopefully)
We are hoping to develop another style of torque box to fit over both intake manifolds (if we do dual) to keep the stock location. This all is going to take a while, so I'll let you all know how it goes.
What ever became of this project?
castro
04-14-2008 09:52 PM
Renick Motorsports
Engine and Drivetrain
09-23-2006 11:29 PM
au112
Canada
07-22-2003 06:38 PM
