clutch chatter
clutch chatter
have an 03 2.5rs with only 2800miles aprox.having clutch chatter when the vehicle is cold.makes the car buck and jerk.subaru has a redesigned clutch disc,throwout bearing and pressure plate.i get to have it installed under warranty.same deal with the wrx's also.
yeah and break the gears in the trans,no thanks,all u people putting ceramic pressure plates w disc are nuts.just waiting for trouble.the gears aren't made for that.maybe if i had an sti trans that would be a diferent story.anyway the reason for the chatter is the clutch disc leaves a resin on the flywheel when cold.youre burning off the resin when the clutch chatters
Su_be_FrEsh
01-26-2008 04:30 PM
kYLEMtnCRUZr
10-25-2006 09:35 AM
cruzinWRX
01-16-2005 06:42 AM
